THE DESCRIPTION of the INTERFACE the TRANSCEIVER-COMPUTER
AND REVIEW of the RADIOAMATEUR PROGRAMS
When I have written a part of
given article I understood that the illumination of the information on
separated directions of a theme is impossible to me. In this
connexion
the information will be general. This theme will be illuminated in other
publications. I advise to radioamateurs to use
wider personal computer with the purpose of replacement of equipment
such as, controllers, filters, digital tape recorders and various
Options for transceivers. I assure you, the computer has these
possibilities.
The analysis of development of
designing modern radioamateur transceivers of
known firms Icom, Yeasu,
Kenwood and others, results in a conclusion, that has a place the
tendency of increasing use of digital methods of processing of a signal
on low-frequency signals and signals of intermediate frequency (today up
to IF up to 22 kHc). The similar approach is
traditional, as in the field of high-quality record and reproduction of
a sound this method is practically sole. By
realization of the increasing frequencies of processing of the
information in processor sphere near is realization of a practical
design of devices without application of analog engineering. It is
confirmed by the theory dr. Kotelnikov about
reflection of wave analog processes by discrete digital meanings.
Already there are designs, in which the most part of functions is
carried out by the computer. It is the professional receiver of firm
Icom
IC-PCR1000, having quite good characteristics. In
radioamateur
practice it is the transceiver issued by firm "Kachina"
under the name "505DSP Computer Controlled Transceiver", which consists
from simplified transceiver not having neither bodies of management, nor display and usual computer
equipped with the advanced hardware interface of communication with
transceiver. In this design of function DSP, reflection of frequency,
style, management of switching by ranges and others is carried out by
the computer. This design is very interesting, it summarizes many (but
not all) achievement in the field of the managing programs of an amateur
radio communication. During last years the
radioamateurs
created many programs having the widest functional spectrum.
It is possible to include in the review of
functions of software of radioamateur
communication:
The analysis and adjustment of
through channels reception and transmitting of pathes
transceiver with a very high degree of accuracy and minimal application of
additional physical devices. The given system is realized by the author
for adjustment of professional and amateur engineering and can partially
replace expensive professional complexes such as: HP 8590 or PSA-65B.
Realization of functions DSP:
Noise Redaction, ANF (suppression interfering carrying in a strip of
reception).
NB (suppression of a pulse
handicap).
Digital dynamic compression of
a signal
Digital filters with a
controlled passband and absolute rectangular
form.
Management of all functions
transceiver from the keyboard or manipulators of various types (for
example elementary valcoder)
Direct (On Line) and Packet
Gate access in Internet for reception of the information from DX Clater. The received information logically contacts
with electronic Log by reflection of the information on ranges in
formats DXCC, WAS, WAZ and etc.
Fast scanning frequencies
received from DX Claster for real audibility anonsed DX.
Emulation of all
kinds of digital communication: RTTY, PACTOR, SSTV, Packet 300/1200/9600
including organization BBS and Gate (sluices), CW (TX/RX), PSK.
System of the
panoramic view of a range of given width.
Reflections on the
screen oscillation of analog signals, AFH of through channels of
receivers both transmitters and multichannel digital oscillation.
Functions of the
digital tape recorder in modes: record and reproduction.
The realization of the greater part
of the listed functions is possible under condition of application
ADC/DAC, sound payment, being a part, of the computer - Sound Blaster
(further SB).
It is necessary to stop on the
description of functions and structure Sound Blaster's, since the
opportunity of realization of the described programs depends on it. It
consists of several separate devices used in various combinations and
modes:
ADC/DAC with the
maximal frequency digitazaiton of a signal
44100 Hz and resolution on amplitude of 16 bits.
Multiplex - switch
of a direction of a signal inside SB.
Wave Synth - synthesizer of wave processes.
Complete duplex
entering and leaving of signals.
Devices MIDI (are
used for musical synthesis).
The management of
all devices SB is shown in system of machine teams
similar processor. Post Fact the standard on system of teams recognizes
development of firm Creative. Last time the most part let out SB uses
this system of teams. At choice SB it is necessary to be guided by
selection SB, adequate to these requirements. Otherwise most part of the
described software will not work. Practically most suitable is AWE-64 of
firm Creative on the bus ISA. It is necessary to pay attention to the
recommendation for use SB of the certain type in the description on each
of the programs.
There is a
number of the recommendations on operation of a board SB Creative
AWE-64.
On a board SB there
are two swish MIC and CON, that means, accordingly, switching in mode of
operations with dynamic or electret by microphones. I recommend to establish
the switch in a rule MIC. It will prevent strongest throws on microphone
of a circuit at inclusion of a microphone in connector since the
constant voltage given on electret
a microphone is removed. In practice are frequents the cases of an output
of board out of operation for the named reason.
It is desirable an
input and output of a low-frequency signal to untie small by AF
transformers equipped with a shielding winding, with the purpose of
protection SB against an output it out of operation.
One of the basic
themes of given article is the description of the interface for
connection transceiver to the computer through which the greatest
quantity of functions of management and reception of the data from
transceiver is realized. I want at once to be stipulated, that the radioamateurs having self-made transceiver or firm
transceiver of old types, must not lose heart, since the most part of
opportunities of processing of a signal and the managements transceiver
remain for them accessible. The requirements to the interface the
transceiver-computer can be formulated in the following items:
Management of
inclusion on transfer PTT.
Management of manipulation CW.
The management FSK
RTTY (deviation of frequency of transfer RTTY and Packet) is direct in
transceiver.
Transfer of a audio-frequency signal to the computer.
Transfer of a audio-frequency signal from the computer in
transceiver.
The interface
Remote Control (CI-V for Icom) and usual
RS-232 for other types transceiver.
Maximal electric an
outcome the transceiver-computer reducing opportunity of failure first
and second.
The circuit of the
Interface of management PTT, CW and FSK
The circuit of the Interface of management PTT, CW and FSK
The interface operates PTT, CW
and FSK transceiver. In the given circuit these outputs correspond to
inputs transceiver Icom-746. It does not impose any specification on use
with other types transceiver. Signals should be
sent on the inputs appropriate to each of types of transceiver.
The input and output AF
transceiver is more preferable for using directly from the demodulator
of a signal and directly on the modulator. The similar
circuit deliver you from additional distortions AFC of a path
transceiver and allow all installations of levels of a signal in all
programs to rest always constant and independent from a rule of bodies
of management of loudness.
THE TABLE FOR MOST FREQUENTLY of USED PROGRAMS
Programm
CW
PTT
FSK
Received
TR-Log
DTR
RTS
RTTY of K6STI
DTR
RTS
TX
EQF Log
DTR
RTS
JVCom 32
DTR & RTS
XMLog
DTR
UA9OSV Key
DTR
RTS
CromaPIX
DTR & RTS
BAYCOM/FLEX
RTS & TX
CTS
GP/FLEX
RTS & TX
In the table there are the names of pins of socket RS-232 which
used for management of the appropriate kinds of manipulation
transceivers of all types.
These pins are set in adjusting parameters of
programs, therefore in the given are included more preferable
installations for unification of work of the interface. It is necessary
to take into account that factor, that many programs at work CW at first
include PTT and in time of a delay (installed in some programs by user)
signal CW. The similar
delay
has the purpose:
To protect contacts antenna
relay from switching with presence HF/VHF of a signal.
To protect transistors from an
overload during the work without loading at the moment of switching from
reception on transfer.
To prevent contraction of
sending of DOT and DASH.
To work without superfluous
manipulations reception / transfer at installation the long delay on
PTT.
CI-V RADIO
INTERFACE Remote Control
CI-V RADIO INTERFACE Remote Control
The circuit of the interface is
the simplified analogue CI-V (Communication Interface Five), used by
firms
Icom (Interface CT-17) and Motorola (Programing RIB). The interface is the circuit reducing
lines of transfer and reception of the socket RS-232 in bidirectional
line. The advantages of the interface are obvious - there is
extraordinary simple inclusion of transceiver-computer and
transceiver-transceiver. In this case it is possible to connect two
transceivers or transceiver-receiver by a usual two-wire line. In this
tandem any devices become simultaneously both conducted, and conducting.
Rotating the handle of adjustment of one of devices you change
synchronously frequency of second. Change of mode (CW, USB, LSB and
etc.) one of devices is caused the change on another. One can use more
devices that two, including the computer, and
the algorithm of management can be very flexible. The circuit is
simplified on a level of a signal, therefore at unreliable work try to
replace port. At failure of work and in the latter case, it is necessary
to apply the circuit of the interface with -5 and + 12V.
To management transceiver of
other types are applied more simple system Remote Control - three wire
(or 5 wire, including signals of readiness DTR and RTS) by a principle
RS-232 with use of transfer given from logic signals RX and TX of the
computer and transceiver.
It is necessary to watch, that
the speeds of an exchange of port RS-232 in the program and menu
transceiver coincide. They can be situated in limits from 1200 up to
56000 baud using format 8-N-1 (2). At non-observance of this condition,
exchange of the data the transceiver-computer is impossible, and
programs using Remote Control, will not work.
Yeasu - released FT-747GX at 90-th years, the firm applies the built -
in interface of transformation of levels for connecting to the computer.
Before such models as FT 990 required connection of the external
interface of a type FIF-232C CAT System Interface.
Kenwood - last models TS-570
and TS-870 have the built - in interface RS-232 for connection to the
computer. Models 450, 950 and 850 need purchase of the interface.
In given clause the circuits of
external interfaces for transceivers of last two named types are not
resulted since the author had not by them to be engaged. For the
experienced users this problem will not make the large work since the
essence of the interface makes usual transformation of a level from TTL
in a level + -12V of a socket RS-232 (direction transceiver - computer)
and TTL - > + - 12V (direction the computer -transceiver). The circuit
decisions of this problem can be found in a plenty of the editions
devoted to digital engineering.
The application of the
interface which is carrying out Remote Control transceiver, has many
advantages, which can be characterized briefly in the following items:
Automatic record in an
electronic Log of frequency and mode.
Automatic scanning DX of
frequencies on search on an own grid or available in
Log'e.
Automatic scanning of
frequencies received from DX Claster.
Management of frequency and
style transceiver from the computer from the keyboard or additional valcoder.
Contest work in a network
several transceiver in a mode multy-multy/single
and operative installation by the coordinator to one or several
operators of frequency received from DX Claster'a
or from the operator, working on search.
The additional control of
reception CW (basic reception, is especial in conditions QRM, is always
carried out by the operator).
Operative access
and control of frequencies 5/10 cells of fast memory and frequencies
Split.
Programming and
automatic switching of a style on various sites of a range.
THE REVIEW and DESCRIPTION of the HAMRADIO SOFTWARE
The review of the
software is carried out according to the recommendations described in
the beginning of clause. The programs have a wide functional spectrum
and use various physical devices of the computer. It is important for
knowing to define opportunities of the computer and to represent, that
can give use of those or other software. The brief descriptions and
recommendations for application are given only on small quantity of the
programs which have seemed to the author of clause interesting or
useful.
TR-Log - Program of an electronic
magazine for Contest.
The address of the author: Larry
Tyree N6TR/7 tree contesting.com tree@contesting.com
About the program: http://www.qth.com/tr
One of the most
popular programs, is especial among the radioamateurs working in Contest, in spite of the fact
that works under operational system DOS. Has the built - in electronic
key, is perfectly adapted to adjustment under a plenty of conditions
various Contest'îâ, requires(demands) only
aperture on the keyboard of the signal correspondent (all other exchange
makes from function keys), enables flexibly to program CW of the message
and, that is very important for simultaneous work of the several
operators, works in a network through so-called zero - modem (port
RS-232). Unfortunately requires input of a range and style manually.
Well processes Log for the report on competitions in a textual mode. The
Interface of management " is necessary only "
for its work.
From lacks - the
manipulator - on parallel port and with additional resistors is
inconveniently connected external CW. I disassembled this program, have
found of the reference to ports and I can recommend simple modernization
of the program - translation of connection CW of the manipulator for
port
joistic, is similar to the program CWTYPE of the
author UA9OSV, described below. The replacement is made in anyone of HEX
the editor in any of the versions of the program. The modernized program
was by me tested in Contest and any deviations(rejections)
from normal work was not noticed.
To find a sequence
byte - 40 8B D0 EC 24 10 3C 10 (contact DOT)
To replace it) on -
BA 01 02 EC 24 E0 3C E0
To find a sequence
byte - 40 8B D0 EC 24 20 3C 20 (contact DASH)
To replace her on -
BA 01 02 EC 24 D0 3C D0
The circuit of connection CW of the
manipulator for the modernized program TR Log and key CWTYPE UA9OSV.
Log EQF - Program of an electronic
magazine with set of the previous versions.
The program can be taken on
www.itis.net/eqf www.itis.net/eqf
The address of the author: n3eqf
usaor.net www.itis.net/eqf
Works under
operational system DOS. Has the built - in electronic key, can be
adjusted on work with a wide spectrum of various kinds òðàíñèâåðîâ. Reflects frequency and style in the screen,
very much îãðàíè÷åííî is able to operate òðàíñèâåðîì. Is slow in a mode
of transfer CW - requires several unnecessary pressing of function keys.
The additional utility Post well will transform textual formats of a
magazine, but the transformation to formats used Windows Log'àìè does not support.
By many is used on a habit, since there are programs in environment
Windows, working more completely.
YPLog - Program of an electronic magazine. The author VE6YP.
The program is
possible is to taken by http://www.nucleus.com/~field/
Works in
environment Windows. A very convenient electronic magazine for usual
(not Contest) work. Can be adjusted on work with a wide spectrum of
various kinds transceiver. Reflects frequency and style in the screen,
very well is able to operate transceiver from the keyboard and
maus. Operatively gives the information on entered signal on
repetition, work with the given country on all ranges, manager, concrete
address, name and
ïð. And from
connected CD Rom or database. Conducts a magazine in a modern universal
format ADIF, converts a magazine in other formats Export and Import. Has
the perfect analysis of a magazine under the diplomas with a conclusion
in a file or Print. Has the built - in interface of an
output(exit) on DX Claster through
batch AX-25 Gate. Very precisely ïðåäåëÿåò the country, zone CQ and ITU on a widely distributed database DXCC
areaok1rr.tbl, updated monthly on site at the author http://www.qsl.net/ok1rr/
TRX-Manager - Log and
program of management transceiver.
The author of the
program Laurent Labourie (F6DEX)
http://ourworld.compuserve.com/homepages/f6dex
The unique program
with set of opportunities. Separate clause is required to describe all.
Shortly: the perfect interface of management transceiver and reflection
of his condition. Electronic Log in the advanced format Microsoft
ACCESS, allowing to the user to edit it in environment Office "to
connect" it to other databases (for example to create a file QSL
Manager's and to connect it with Log) and to convert in any formats. ON
Line and Packet Gate of access in DX Claster c
by the subsequent automatic processing of the received data according to
Log. An opportunity of scanning of frequencies received from DX Claster. Reflection of a panorama of a range with any
width. An opportunity of start in environment of the program of other
programs (for example of filters DSP, digital packages RTTY, SSTV, CW
Kay and others of Log). Record and reproduction AF of signals in a
digital format.
Demo the version http://www.infracom-fr.com/demo/trmde.exe
DSP Blaster - program
which is carrying out functions, similar DSP transceiver.
The author Brian Beezley, K6STI k6sti n2.net
k6sti@n2.net
The program carries out not only all
functions standard DSP:
Noise Redaction
(noise bluncer) with very thin adjustment in
three strips of a speech spectrum of frequencies.
ANF or suppression
interfering carrying in a band of reception.
Change of a passband of the digital filter from 50 Hz up to 3000
Hz with any strip and step 50 Hz.
Change of
frequencies of the filter from above and from below on any of
frequencies of the specified range.
Built - in SQELCH c
by a wide range of adjustment.
AGC with
changeable
speed.
Very wide range of
adjustments of levels entrance and target of signals.
The author of
clause compared qualities of the program with built - in in Icom 746 DSP on reception
and on transfer and has come to opinion, that DSP Blaster in some cases
it is more preferable than first. The program is written in language of
the assembler and works under Windows in a mode of emulation DOS, but it
does not belittle its advantages.
CW Key UA9OSV
The author http://ua9osv.da.ru
The program
consists of two parts: the program of transfer CWTIPE and program of
reception CWGET.
By the one who has
not built - in transceiver of a key and is going it to get or to collect
it, I urgently recommend at first to try this program. Except for
standard and it is enough flexible ìàêðîñîâ of transfer of the prepared messages, the program has unique
feature - function of the manipulator are loaded ðåçèäåíòíî and at transition to work in environment of any
other program CW the manipulator does not cease to work. The effect
constantly included and similar built - in of an automatic key is
created. The second convenience is the connection of the manipulator on
port Joistic, as a rule always free. Can work
with a programmed delay PTT/CW, about which advantages was told above.
The circuit of connection is given in the description on TR Log.
The program is
freely distributed also her it is possible to take on ñàéòå from the author http://ua9osv.da.ru
A lot of good it is
possible to tell and about other programs, such as
RITTY of the author
K6STI, is doubtless by best in a line of the programs RTTY;
JVCom32 and
CHROMAPIX of the programs of reception and transfer SSTV;
MIXW32 of the
universal program, which distinguishes an opportunity of work by
protocol AX25 with speed 300 bps/with (through SB) author UT2UZ of http://www.tav.kiev.ua/~nick/nick.htm
The radioamateurs
can successfully use the programs itself Windows.
For example, before
to get the built - in digital tape recorder, you can try simple
operation - to write down in WAV (sound file of wave structure) the
signal and general call and to transfer by their pressing of one key. If
to ask any radioamateur how many sometimes of
hundreds time to it to have to repeat signal in powerful PILE UP'e or general call in Contest … I think the answer
there will be one - MUCH.
Write down and textual file with
expansion *.bat the following:
trx _ on.exe; start of the program of inclusion PTT
start /w /m
sndrec32.exe /play /close cq.wav; the program of
reproduction of a sound file
trx _ off.exe; start of the program of
deenergizing
PTT
Such programs can
be much and to differ they will be names of started files *.wav, and to
cause this or that you can from convenient for you ìàêðî of the programs given Windows. The programs trx _ on and off everyone can write on the
mathematical programming language, accessible to it. And as a last
resort to receive on ñàéòå of the author of
clause TRX _ ON and TRX _ OFF TRX_ON & TRX_OFF
It is necessary to
take into account, that the programs are
written ONLY for management PTT through port COM1.
73's Roman RU3UJ
PS:
Excuse for my bad English language.
